ChuckM said:[scared]
Blunder x 2!
Sadly, yes. If I had brought my tape measure with me the first time, it would have been Blunder x 1. [mad]
Blunder x 2!
As far as metric tapes I use a couple Stanley Fat Max’s, (a 5M and an 8M), and several Tajima’s. All of those have been verified against my steel rules.serge0n said:[member=8008]tjskinny[/member] and [member=2575]thudchkr[/member] - thank you! Such an eye opener. I was sure the Fastcap tape was pretty accurate, looks like that may not be the case.
I will check it against a good American made steel rule and report back.
I did another check yesterday by making a mark at precisely 500 mm with the Fastcap tape. It was about 0.7 mm out on the TSO guide scale, not as bad as 1 mm, but still frustrating.
I made a test cut at the 10" mark with TSO guide and it was dead on, exactly 10" according to my Woodpeckers stainless steel square.
[member=2575]thudchkr[/member], you had an interesting observation regarding the temperature change. How big was the temp swing?
IIRC temp in the shop was around 53 degrees F. I’ve meant to check it again at a higher temp but have yet to do so. If I need a precise measurement, I rely on one of the steel rules.
Does anyone have a recommendation on a metric tape that is more accurate than Fastcap's True 32?
Michael Kellough said:![]()
Take note of the chart to the right of the pic of the tape measure on the display carton.
serge0n said:The Hultafors Talmeter has arrived. And I'm not impressed at all.
It's a class 2 tape, so the scale is not printed with injket, but transferred with a special wheel. It looks really crappy.
Here is the Talmeter tpae as compared to the Festool tape:
Snip.
ChuckM said:Was it due to some manufacturing malfunction? My dollar store kind of tape measure (class 3?) has even better printing.
jeffinsgf said:I checked my Talmeter yesterday after seeing this thread. Rabone-Chesterman, Bridge City Toolworks, Woodpeckers and the Talmeter all aligned perfectly with each other. Guess I got lucky.
I wish I had your kind of luck with my tapes.jeffinsgf said:I checked my Talmeter yesterday after seeing this thread. Rabone-Chesterman, Bridge City Toolworks, Woodpeckers and the Talmeter all aligned perfectly with each other. Guess I got lucky.
thudchkr said:I’m looking forward to comparing them to the Tajima’s I currently own to see how well they match.
I plan on posting the results here when I come up with some details.
