Packard said:I would probably stick some adhesive backe sandpaper onto a 1/2” diameter dowel.
Leave about 6” of bare dowel at each end. The bare dowel will not cut and will act as a guide for a consistent angle. A few quick swipes should do the trick.
No equipment purchase required.
Note: This works perfectly in my mind, but I have not tried it.
darita said:Does this tool work well and NOT expand the hole size? I want the chamfer however I don’t want to loosen the fit of dogs.
tsmi243 said:So we're all on the same page- there's 3 different tools from Axminster
Reamer-
Chamfer-
Reamer AND chamfer-
darita said:Too bad they didn't make a tool that would chamfer with your drill, but not ream.
[member=69167]RMW[/member] -Richard/RMW said:I have one that I stopped using, it's too much trouble other than for the odd hole every now and then. I don't think it opens up the holes however, it's a slip fit and only needs to be rotated 1-2 times.
Xmas before last I bought one of Ryobi's battery/charger deals ($99 using a $100 gift card, so net cost to me was sales tax-$1) and got a "free" palm router that is now dedicated to a chamfer bit. It's amazing how often something "needs" a chamfer when it only takes a minute to do. All my dog holes get the Ryobi treatment now.
As [member=44099]Cheese[/member] stated, many dogs now require it to work properly. I've found that style of dog is less susceptible to needing a perfect fit since the chamfer acts to self-center them.
RMW
Cheese said:Packard said:I would probably stick some adhesive backe sandpaper onto a 1/2” diameter dowel.
There are some dogs on the market that need to have a UNIFORM chamfer at the top of the hole to function properly. The chamfer also needs to be a substantial depth. Enter chamfer tool.
The chamfer only tool that tsmi243 mentioned is for MDF only…not to be used in ply.
TSO_Products said:[member=69167]RMW[/member] -Richard/RMW said:I have one that I stopped using, it's too much trouble other than for the odd hole every now and then. I don't think it opens up the holes however, it's a slip fit and only needs to be rotated 1-2 times.
RMW
Richard, your approach with a dedicated router has served us well in our shop. Your observation that the chamfer Collar on the Dog aids in centering has also been borne out in our own shop experience.
Last but not least our customer service records support that these features get the job done for large number of our woodworker cutomers. If there is something that we should emphasize or play down on our website regarding Chamfers to make it more helpful, do let us know, please.
Hans
Cheese said:darita said:Too bad they didn't make a tool that would chamfer with your drill, but not ream.
You can always make your own... [smile]
