Corwin
- Jan 22, 2007
JSands said:In addition to solving the auto-vac-on, I also ordered the 50mm hose for the CT22 vac... I would like to improve the dust collection as well. Once I get it all "just right" I will consider my 75 plunger for sheet breakdowns, a great alternative to a sliding table saw...while all these accessories cost more the saw itself (including the 118" rail, dual Gecko's, clamps, vac switch, 50mm hose, etc.), as I see it, this system will perform equal to a sliding table saw... at least for my needs... as I don't break down 50 sheets a day.... so in the end, a much lower cost, and most importantly, it dissapears when I am not using it, freeing up work space...![]()
I can understand upgrading from a D27 to a D36 hose, but I don't see where getting a D50 hose is going to work well. First off, Festool doesn't make any tool-end fittings for the D50 , so you would need to work that out on your own -- you would probably need to step down to the D36 size at/near the tool. Then, there is the stiffness of these hoses -- the bigger the hose, the stiffer and less flexible they are. Aren't these issues gong to be a problem for you if you use the larger D50 hose? And wouldn't the D36 hose be the better choice?
