Programmergeek
- May 2, 2007
I bought the laminate trimmer and intended to use it as small router as well a laminate trimmer until I mounted a bit in it last week and found you can not see the bit the base is solid. I know there are guides on the base but that does not help me trying to follow lines in small areas. Is there another base I am missing I got the big kit? Should I go out a get a bosh cult for a small router?
