I'm just curious how I would go about drilling the hinge cups using the lr32. I know that the hinge plate will mount into the existing lr32 holes in the cab, 80mm from the top of cab. The question is, if the door panel is 1.5 mm or so smaller in both dimensions, wouldn't I need to account for that when setting the track onto the door slab?
Wouldn't I need a .75mm spacer between the stop on the guide rail and the door slab to land the cup dead center?
I'll be looking through big rocks series again but i'm off to cut cab sides now.
