Using Track Saw on MFT
Just another thought.  Sometimes storing a 4' x 8' x 3/4" or thicker sheet of foam is an issue.  At least one of our members who does work on site cuts his sheet and then uses duct tape to create accordion style hinges.
[2cents]
I just built an mdf top using the Parf guide system. I don’t want to cut into the top so my plan is to use a smaller strip of mdf under the rail that will have the kerf line cut into it I will drill some holes larger than dog diameter so that I can place dogs through it into the table for supporting the workpiece . I also want a dog under the guide rail close to the cut for good stable support for cross cuts.
