Dave Ronyak said:
I have Item # 454767, the SS Cleaning set for workshop, D 36 WB-RS-Plus. It is well made and all the wear parts of the HD nozzle are separately replaceable, but expensive, and in my opinion, a bit awkward to use compared to the Fein and any household floor sweeper I have used.
The kit I purchased for my Fein cost about $80 (5 years ago) and included SS extension tubes, too. It's floor sweep nozzle is narrower than that of the Festool kit.
Dave R.
Dave,
I read over your post and a couple from earlier disscussions that we were having. I think that I recall seeing that you have an OF1400, a Fein II, a CT22, the nice floor kit that I was looking at, the Fein floor kit and the boom arm. As this is a duscussion of what I would not buy again, do any of these items qualify?
Right now, the Fein III is about $360 and the HEPA Filter is around $100. That would seem to put the CT22 and the Fein III at the same price. The Fein doesn't have the variable speed of the CT22, the bigger wheels, nor the systainer storage cabability. I have heard that the Fein is quieter and it does have a lot more capacity. I don't know about the differences between the variable amperage draw of the "auto on" feature. Do you think that you'd get the Festool or the Fein?
I looked at the Dust Deputy and it seems very convienent to empty, compared to pulling the Fein or Festool apart. If I got one of these, it would negate the storage capacity difference between the two.
About the SS cleaning kit w/ aluminum floor sweem. You mention that the Festool floor sweep is awkward. How so? Is the smaller Fein one just as good, at less than 1/2 the cost? I recall you saying that the tubes are larger on the Festool and less likely to clog. So, would you get the Festool kit again? Or only the SS tubes and use the Fein kit? I currently use a lot of the accessories from our old house vacs on my Fein. They connect in with the neoprene connector.
In the other post, you mentioned needing to use the 36mm hose to collect the dust from the OF1400, if you didn't want to clog up the hose. Is there any special attachments needed?
I liked your idea of hooking up the "Y" connector to your router table. Currently, I took an old 8' vac hose I had laying around and hooked it up to the top of my router table. The hose is like 2 1/4" or something. It plugs into my Fein II at the body with only friction and works perfectly. The only problem is that I still have to vac out under the router table. I was thinking that your set up with the Y and the DD would be perfect for this.
The last question is about the Boom Arm. In going with the "I wouldn't buy that again" idea, what do you think? Given that the boom arm has gone up in price and that you have to have the handle and the boom arm ($293 combined), is it worth it? I will use the vac about 90% of the time in my own shop. I was thinking that a ceiling hook or a wall mounted homemade boom would be considerably cheaper (although, likely not as purdy).
Just for the Festool vac & fittings, I was looking at over $1000. Trying to figure out ways to cut costs...
Thanks for sharing,
Rod.
