semenza
SRSemenza said:A couple pictures to go with my old post above.
[attachimg=1] [attachimg=2]
thedevme said:This is a great idea but what do you do if the board is wider?
Sparktrician said:thedevme said:This is a great idea but what do you do if the board is wider?
Use layout lines and align the DF 500 to the marks. [smile]
thedevme said:Sparktrician said:thedevme said:This is a great idea but what do you do if the board is wider?
How do you keep the domino from moving? I tried something similar but I got inconsistent results [member=7493]Sparktrician[/member]
Sparktrician said:thedevme said:Sparktrician said:thedevme said:This is a great idea but what do you do if the board is wider?
[member=69101]thedevme[/member] Plunge the DF 500 S-L-O-W-L-Y!!! Listen to the motor pitch. If it changes radically and the DF 500 is shifting position while you're plunging, you're plunging too rapidly. [smile]
RKA said:You can also brace the side of the fence that wants to scoot away from your clamped straightedge with your thumb and index finger. It's just a router. The bit turns in one direction, the body will be forced in the other direction so you can apply a little force to counter that twisting motion. This can be a problem with smoother surfaces where there isn't enough friction to keep the domino in place. But most of the time, if you're not plunging too fast it's not an issue.
thedevme said:SRSemenza said:A couple pictures to go with my old post above.
This is a great idea but what do you do if the board is wider? [member=1619]SRSemenza[/member]
thedevme said:I decided to use this -https://www.infinitytools.com/2-wide-straight-edge-clamps-3126 I also plan on getting a 100in one for longer boards when I need it but I didn't like how long it takes to clamp a track or whatever so this gives me a straight edge and clamp all in one. Thanks everyone for the ideas.
ChuckM said:Do those clamps allow you to adjust the clamping tension? I can't be sure, but i have one of similar clamps and will take a look.
