What is the inside dimensions of a sys-port 1000?
veric13
Hello,
I am looking at making an assembly table with sys-az drawers and trying to figure out some measurements.  Does anyone know the inside dimensions of a sys-port 1000?  There is a chart that shows what systainer combinations can go in one in their catalog, so wanted to start there.  Thank you.
The front opening of the Sys-Port 1000 is 430mm wide by 938mm tall. Keep in mind that the Sys-Ports have their own drawers and do not use the Sys-Az drawers, so your dimension may need to be somewhat different -- I don't have any of the Sys-Az drawers, so I cannot be sure about what dimension you will need.
Also, the Systainer 5 doesn't fit in the Sys-Port the same as the other sizes -- it has too much space remaining above the Systainer 5 such that the Systainer is not secure and can be lifted out with the drawer shut and the Sys-Port locked.  [crying]
