timwors said:
			Accepting the points about batteries, don't they already have the TS60K motor, which is 1500W and mains powered, and even takes the same size blade as the CSC SYS 50. It's basically doing the same thing? The voltage conversion would then only be needed for the electronics, which is low-powered and a much easier proposition.
I expect quite a few people (like me) are put off from the big investment needed for batteries that probably have a much shorter lifespan than the table saw.
The TS 60K is running at 110V. Not 36V. That is a third of the current right there.
That and the TS 60 motor not really being 1500W, it has higher peaks apparently - why it was denied a PlugIt. I would guess both the TS 60K and the CSC have load peaks/transients easily in the 3000 Watt range. As mentioned, no way to get this in a compact form factor.
Plus, having an AC-DC converter with about the 2-3 kW peak capability needed, you may just as well build a dedicated AC motor. Would be actualy easier/cheaper.
EDIT:
				Svar said:
			Metabo HPT 36V Brushless 10in Table Saw runs from a fairly small 2000W adapter. Surely much smaller CSC SYS 50 can do the same.
Noone is saying it cannot be done. The point is it cannot be done at a sensible size/cost
and without compromising the tools when battery operated. By the way, that HPT adapter is positively huge. And that is only 2000W (possibly 4000W peak ?)
HPT designed most /all ?/ their tools with the limited AC-DC setup already in mind. That means capping their performance inevitably.*) To them, the trade-off was worth it. Good. But they are neither a top-end niche maker, not a smaller/niche player who needs to think how to recoup R&D costs from way smaller sales volumes.
For a fact I know how much it would cost to make a two (yes, two as Festool uses 18V setup so two independent power supplies would be needed) power supplies in the 70A@18V range to not trip when a battery would not. About $200 per piece, so about $ 400 on cost only. A friend was developing something recently for a small series production (2k pieces) and that is the ballpark of the *lower* quotes he got. Giving about $600-$800 retail price for a set. Considering that the CSC with a pack of 8Ah packs will last several days of small trim work, a week+ of artisan work, I just do not see how it is worth it. It is not a jobsite carpentry saw for a start, so types of workloads it will see are way lighter compared to that HPT jobsite one.
my 2c
PS:
*) unlike a switching power supply, a battery is self-load-shedding by not being a "hard" current source, this means that a battery pack has no issue providing/handling/attenuating load transients "automagically". An AC-DC converter (without a battery included, or a huge and heavy capacitive coil) cannot take advatage of this so needs to be way over-build OR the tools must have a software current load cap to prevent overloading the inverter. one way the thing needs to be ridiculously huge/overbuilt, other way the battery operation of the tool has to be capped in some way. Can be done. Absolutely. But no "free lunch" on this to be had.
