which Felder to get?
HowardH
Albuquerque
I am planning on selling my Hammer K3 Winner in a few months and get a either a KF500 or KF700.  I saw where you can order the 700 without the electric drive or display.  What's the difference then between the two if you don't want the electric drive?  They look pretty much the same and use the same motors etc.  I'm sure the 700 is a few thousand more.  Can you put the mobility kit on the 700?
Howard the KF500 is basically a Hammer saw and shaper with an X-Roll slider. It has the smaller shaper unit and hood but you can use all the P rail attachments. You also can only get the shorter sliders. If you want to truly upgrade you go the KF700, a more robust saw unit, better shaper with the larger 240 hood. The chassis is more robust and doesn't use concrete to counterbalance. I have previously owned a K500S and have a friend that has the older style KF500. My friend would update in a heart beat if he was a little younger, and I have owned the K700SP since 2010 with a separate F700Z shaper.
John
That's very interesting so the KF500 is really nothing more than a glorified Hammer B3 (not a bad place to start, however!) with the X-roll table.  It seems to me get a "real" Felder you gotta start with the 700 series.
That's it Howard, IMHO the only saw in the 500 series which is different,  is the reasonably new K540S which has the dual trunnion setup of the 700 series but has been setup to take a 14" max. blade.
John
Concrete!
Tell me more..
John
There's a lot of detail in getting your KF700 configured the way you need it. I'm still a way away from pulling the trigger, but for interest .. here's the configuration I'm looking at (It's for Australian delivery and would set me back $AU20K+)
FELDER CIRCULAR SAW-SHAPER KF 700
1 - ST 424-70009 - Saw unit with double trunnion for saw blade dia. 250-315 mm (350 mm non CE) Cutting height max. 104 mm, saw spindle dia.30mm speed 4800 rpm Electrical height adjustment Electrical angle adjustment Digital display for height and angle
1 - ST 424-50022 - Emergency Stop Button instead of Off-Button
1 - ST 420-70008 - EURO II saw guard riving knife G" - EURO safety hood, push stick
1 - ST 423-70025+1 - Circular saw fence with fine adjustment Round bar guide with ruler
1 - ST 424-70017 - Cutting width 800 mm with additional table short for KF 700 (S)
1 - ST 423-70030+1 - Scoring unit with motor 0.65 kW S6/40% 1 x 230 V, 50 Hz Max. sawblade diameter without scoring blade: D= 315 mm Max. sawblade diameter with scoring blade: D= 300 mm max. cutting depth 2 mm
1 - ST 420-70010 - Scoring blade cover
1 - ST 423-70027 - Label for scoring unit
1 - ST 430-20057 - Sliding table, Table length 1300 mm Anodised 10 years Felder warranty on the X-Roll sliding tableguiding system
1 - ST 424-80007 - Spindle moulder unit with double trunnion, Rapid change system for spindle, Table opening 230mm, spindle tilt with hand-wheel 901⁄2-451⁄2, dust extraction below table Electrical height adj. of spindle moulder Electrical angle adjustment 901⁄2- 451⁄2 with adjustable end stops. LED display for spindle height and angle. (Power Drive F2)
1 - ST 424-80015 - Moulder spindle D-30mm,shaft length/clamping height/useable length above table (901⁄2) 117/ 124/115 mm, 3500/6500/8000/10.000 rpm
1 - ST 424-80010 - Spindle moulder fence "230" Spindle fence with stepless micro adjustment depth of the outfeed fence plate, easy locking of the fence with big handle device
1 - ST 410-80017 - Fence Plates 400 ALU ANODISED for Spindle fence
1 - ST 423-80015 - EURO II guard for spindle moulder fence
1 - ST 400-07876 - EURO Adjustable curve shaping device
1 - ST 430-20021+1 - Crosscut fence 1100 mm
1 - ST 424-40213 - Electrical system 1x230V, 50Hz, 3kW S1 CE/US
1 - ST 424-40201 - 50 Hz motor frequency
1 - ST 424-10003 - Machine Base KF 700 Min transport width 800 mm
1 - ST 424-10012 - Cover for outrigger connection
1 - ST 424-90202 - Operating manual CF 741/CF 741S, English
1 - ST 424-30013 - Packing STANDARD 2100 x 1200 mm IPPC
1 - ST 420-30011 - Preparation for container transport for KF 700
ACCESSORIES
1- ST 03.02.30048 - TCT universal saw blade D=300mm W=3.2/2.2mm d=30mm 48T ATB
1- ST 03.09.10024 - Adjustable TCT scoring saw blade D=100mm W=2.8-3.6mm d=20mm 12+12T
I'll probably delay this purchase quite a while as I'm tossing about the idea of moving [sad]
Iceclimber said:
Concrete!
Tell me more..
John
My K500S had a 98" slider and because of the lighter, Hammer style under carriage had a large formed concrete counterbalance in the floor of the saw cabinet. At the time (2008) I was told it was an anti tipping safety feature weighing around 300 LBS.
John
Kev a couple of suggestions to your configuration would be going for the shaper integral fence plates 500mm which would be the Aigner fence. Also instead of the Felder curved shaper hood look at the Aigner Bowmould system, both are more money but far superior. The last would be an accessory for the slider not in the machine details, its called a parallel fence with table PN 430-149. Also don't forget a power feeder and tilt away bracket.
John
I mean nothing by it with regard to your machine but i would be pissed to find out the weight of my machine was due to concrete vrs metal.
Good info to have moving forward as a slider is my next purchase. Maybe i will have to consider another manufactuer. Kinda a shame being i have three Felder machines to date planning on more.
kcufstoidi said:
Iceclimber said:
Concrete!
Tell me more..
John
John
John
[member=4907]kcufstoidi[/member] thanks for the pointers to Aigner .. awesome looking upgrades [wink] [big grin]
John
[/quote]
[/quote]
I would only be concerned if considering a Hammer with the longer slider or the K500S with the longer slider. The smaller entry slider machines do not need the extra. The 700 series and up don't need or use. I sold the 2008 K500S I had and replaced it with a 2010 K700SP with a 126" slider for cutting sheet goods easier.
John
WarnerConstCo. said:
Really? They have to add concrete to machines now?
  We know Darcy, shocking info to the owner of massive cast iron machines like yourself..... [poke] [poke]
Hey, at least it's not Chinese drywall stacked up inside the base of a machine to add weight/stability.
Glad to see I'm not the only one put off by a concrete filled machine that cost thousands of dollars.
Seems like the kind of info that should be listed in the description or under the specs.
Very annoying!
hmmmm.  No concrete in my K3 but maybe it's because I have a 48" slider.  Luckily, I have a Felder rep and showroom in my town (Dallas).  I will be paying him a visit before I order anything. I just hope I can sell my slider when it's time.  Not too many people who hang out on CL have ever heard of it.
