Which Oscillating Spindle Sander would you get?
wow
Honorary Member
I need to pick up a stationary Oscillating Spindle Sander. In keeping with my green addiction I would like it to be a 'best in class' product if possible and affordable.
What brand(s) and models should I be considering?
I'm very happy with my Ridgid spindle sander which I have owned for about 7 years.
As well as my experience, I have read and heard nothing but good things about it from other owners and reviewers.
[attachimg=#1]
Ridged was rated the best by Fine Woodworking, I have one and it works fine, storage system for components on the machine is poor, always want to fall out when you move the unit. No complaints.
Strange, I would have said that the storage system is good.  [scratch chin]
I have had my ridgid for 5-6 years and when you need it there is no substitute. Very pleased with it.
Frank
The Rigid gets great reviews on the various sites I checked before buying mine. At about 200 bucks, it is a great deal. Multiple spindle sizes and a belt sander as well. The belt mechanism does not store on board when not in use, but I found the storage for the various spindles and their associated parts quite good.
The belt assembly stores in the rear.
OH--- errr.. ???  Hmm, mine stores in a nearby drawer! Guess I should double check then eh-?!!
Well son-of-a-gun!
[attachimg=#]
I thought 'best in class' and 'affordable' were mutually exclusive terms. ;D  Since you mentioned a stationary sander, I am assuming you do not want a benchtop model.  If I were looking in this category I would give serious consideration to the Max OVS spindle sander.  For a benchtop sander, I think I would opt for the Ridgid as many others have already noted.
The tilt table is designed to be lowered when moving the unit to keep accessory tools in place.
+1 on the Ridgid.  Very practical, very reasonably priced and it works.  I've had mine for 5+ years and like the silting table, storage, and that I can get belts and sanding tubes from HD.
Steve
[attachimg=#1]
+1 Frank
[attachimg=#1]
I agree with Frank (and several other posters) that the Ridgid unit is quite good for the price BUT (at least just hooked to a Festool CT-26), the dust collection is atrocious! (notice dust in Frank's photo) I hope once I get my Clear Vue Cyclone hooked up that this problem will be cured.
Regards, Dick
The problem with oscillating spindle sanders (OSS) is that they run in two price categories: 1)around $200 with ridgid judged the best because it also can be used as a belt sander and 2)in the $1,000 - 1,500 range for a precision machine.  The main difference is how much you have to fuss to keep a given angle.  Many of the $200 wonders will tilt, but you better test that angle often because it tends to slip after a few minutes of use.
With my limited budget, I have the Ridgid.  I need to get a dead square 90 degree angle, which means fooling with the thing every few minutes or tossing bad runs.  It just isn't made to keep its calibration.  I see the "belt sander" as a gimmick.  Sort of "nice to have if I were stranded on a desert island", but not something worth fooling with for real precision work.
I have used high end industrial OSS's and they keep their settings, have large tables for stability, but they cost 10x what the ridgid does.  Sigh......
I have yet to see an OSS with great dust collection, so I won't fault the rigid for that.
If I had to buy again, I would probably put a paper bag over my head and get another ridgid.
Video on that Rigid  , I'm gonna get one
as Jesse has  pointed out above the price differential between a really good one & a not so good one is Very WIDE .
that Rigid looks to be for me
I have the bench top Delta OSS, as well have a 48" stand model belt and disc sander so the tilt option table for my OSS is not important to me. A good selection of spindle's came with the unit and replacement grits are plentiful from the WW suppliers here. I'm very happy with it, does all I ask of if. It's in the
I too have the Rigid, had it from when it was first introduced and yet to have any issue at all, I have used it quite a lot over the many years.
For me it's a high recommend
Sal
Frank
Dittos!  I use the oscillating belt sander drop-in as much as the drums.  Really easy to change between the two.  The on board storage is OK, but mine is not removed from my shop.
Guess I'm out of touch. I have a Clayton 9 1/2". Table doesn't tilt. All storage is on a provided shelf. Dust pick up is pretty good .Plenty of power. MARK
