jmbfestool
- Jan 9, 2009
darita said:I also read that the new guard is harder than the old, so it tends to slide easier over wood...not good when you want the guide rail to stay in place.
Definitely some mixed reviews here. Hmmm...is the old black guard still available?
I like the clear for visibility easier to see where to place the rail to your pencil mark especially if you get a shadow line.
BUT
Everything else with the clear is totally crap!
Adhesive with the clear is crap
The fact the adhesive does not cover near as much surface on the strip is the main cause why they peel from the edge because dirt can work its way under more easily. Plus they have used a weaker adhesive I believe.
Also I preferred the rubber feel on the black one it helped grip the material better when cutting narrow stock, unlike the clear which is more hard plastic is very poor.
I my self will only buy the Makita black untill festool makes a clear version but with the same benefits the black strip had.
