Air Compressor Fittings
Mike Goetzke
I use 1/4" quick disconnect on all my air tools. Probably most from Harbor Freight. In the past year I have had 2 or three break when I put the tool down (maybe not as soft as I should). Many years ago a guy at work told me to use 3/8" but 1/4" is so much easier to find.
My question is do I need to use a higher quality 1/4" QD or change over to 3/8"?
how are they breaking i'm amazed by the concept. if you are smashing your tools a 3/8 will just make the break at the next weak point instead, like the tool itself or the threads.
unless you have some very crappy fittings. i'm looking at my brass ones i can't see how they would snap
Yeah - maybe its just cheap fittings. They are brass in color but some kind of steel with very thin wall where it cracks
There's absolutely no way they should break even with very rough treatment. At worst mine have dings on the end from many years of use, and they certainly haven't been looked after carefully.
This one broke with a tire filler with gauge. So not much weight and I didn’t throw it down.[attachimg=1]
Mike, I've always purchased Milton fittings...ya ya ya I know you have to seek them out, and they may be difficult to find, but after 50 years of hard use, they just work. I'm a car/motorcycle guy with pneumatic wrenches and the air fittings don't get treated with kid gloves. They lead a rough life. I've never had an issue with a fitting failing.
Apart from an air nozzle I can't think of a single pneumatic tool that would not suffer from lack of air from a 1/4" air line. A big issue with small bore air lines is the high air speed in the line carries a lot of moisture where a larger line will have a slower air speed and not carry excessive moisture to the tool.
When I was growing up, my neighbor owned a factory that produced pipe fittings. These were all made from solid brass or copper.  They started with billet and machined away the unwanted parts.
He once explained his business.  He claimed he made no money at all on the production of the pipe fittings.  That 100% of his profit was in the scrap brass he sold.  (They produced a lot of scrap.). I don’t know if that was entirely true, but it reinforced the point that he was in the business of removing material, not assembling components.
The metal grain travels in the direction of manufacture.  So if you are proving heavy rods, the grain runs along the length of the rod. It is only likely to bend along that length.  It is not going to crack.
That is, if it was produced the traditional way.  However, if they have figured out that it is cheaper to join two pieces of brass by brazing, instead of simply machining from a larger piece of solid brass, then parts could crack as described.
I suspect that the Chinese (or Vietnamese, Ceylonese, or whatever-ese they import these from) have figured it is cheaper to braze components together and then machine, rather than machine from a solid billet.  In any event, I suspect that these cracking failures are the product of “production efficiencies”, which in this case means more labor but less material.
I bought my hose fittings from Home Depot many years ago.  No cracked parts.  But I have little faith that Home Depot’s buyers have the self-control to continue to buy the better components if a lower-priced-but-likely-to-fail version is available.
I agree on Milton as a standard in most situations.
I have been using Milton for as long as I can recall and have never had a broken fitting. They will leak after a number of years and I just replace them. I tried buying seal kits but it is not worth the time, considering the price of new ones.
Neil Young has a snappy little tune that probably describes your situation ;)
rvieceli said:
Mike - Milton fittings are usually the go to for most folks. There is a significant selection available on Amazon
https://www.amazon.com/s?k=milton+air+fittings&crid=ZD6F1EM6NKLV&sprefix=%2Caps%2C163&ref=nb_sb_ss_recent_2_0_recent
Ron
Just bought the Milton kit.
Years back I had an IR 60 gal. compressor but after I bought a Fuji HVLP unit I sold the compressor and bought a California Air 10 gal. 2HP compressor and love it. Couple months ago I bought a CA 8 gal. 1HP aluminum tank compressor for around the house (just under 35#) - really like this unit so far. So several fittings to replace.
+1 for Milton, but I may be biased as my grandfather was one of the two Miltons that started the company. I'm know he'd be thrilled to hear of all the happy customers.
