An Unusual Project - A Coffin (Casket)
Jonathan,
Totally understand.  Yesterday I put my 101yo mother under hospice and I'm not sure if she will not be visiting with Kate by morning.
Your expression of love for Kate could not be any greater and I'm sure she feels it.
Best wishes of comfort to you.
Jack
Incredible personal commitment.  When is the day, and know that all of us that followed the journey will be standing with you in spirit at least.
You've provided great detail about the project which I really appreciate, making a coffin has even crossed my mind before so this is interesting for me on that level, but I'm sorry to say that all I see in every word and picture is your heart and deep devotion, even now still taking care of your Kate. Peace to you sir.
Jonathan, I have the greatest respect for what you are doing and you have my heartfelt condolences for your loss.
It is a testament to what you shared with Kate that you have the strength to do this and share the process with us. Thank you.
Your design and construction is far superior to any I have seen. ( I worked in a Schreinerei in Germany and part of my job was preparing coffins for use and resting the departed in them)
Kindest Regards
Rob.
My thoughts are with you. You have my deepest sympathy and am sure that you will treasure your memories
Incredible work, while going through incredible emotions.  And to document the design and build while under such pressure, I... I can't imagine.  Much respect to you.  I shed a few tears while reading the project description.  My condolences.
Yesterday was a hectic day - I had some errands to do in the morning (including collecting the new walnut pieces) so didn't get started until around 1pm.
I needed to make a steam box to bend the walnut. I had some PVC soil pipe, but had read that it wasn't suitable as it would soften with the heat. Luckily I had a short (~600mm) piece of underground pipe that had a thicker wall, so decided to use that. I sealed the ends with multiple layers of gaffer/duct tape - the answer to everything! - leaving a 50x25mm opening so that I could slide the timber through.
I bought a cheap wallpaper steamer to generate the steam, and taped that in to one end too. I had a couple of pipe clamps so I secured the pipe to a board, with one end raised, and then drilled a small drain hole at the opposite end for any condensate to drain out. I then wrapped some insulation round it.
I decided to do a test with one of the shorter pieces, just to see if I'd got the radius of the curve right, and how much springback there would be:
[attachimg=2]
[attachimg=3]
Success!
The radius and the amount of springback were just about right, I got quite lucky on that. I'd left the timber to steam for around 50 minutes. I was aiming for an hour as I'd read 1 hour per inch of thickness, and the timber was 25mm. Unfortunately the wallpaper steamer would only run for 50 minutes before the water ran out & it shut itself off. So, on with the actual pieces.
The first one went fine, but on bending the second it unfortunately cracked:
[attachimg=4]
It wasn't too bad, so whilst it was in the jig, I used some black solid-surface resin to fill & stabilise the crack. I didn't have any brown, but figured black wouldn't look too bad.
I dry-fitted and mitred all 4 walnut pieces before sanding and rounding over the edges with a 6mm bit. The curved pieces were, if anything, curved a little too much, and required some serious force to get them straightened a little. When I did the test piece I only left it in the jig for around 20 minutes; the actual pieces were each in there for over an hour. I guess that made a difference! Then I took them off and glued them one at a time, working around the box. I mixed some PVA and sanding dust to fill the last remnants of the crack, and sanded it back in situ, before putting a coat of oil on.
Here's the result of the crack repair:
[attachimg=5]
And the finished item (the blue plastic is some strips of thick plastic sheeting, so I can remove the lid):
[attachimg=6]
All that's left to do now is insert & trim the walnut dominos once Kate is placed inside.
Overall I'm very happy with the end result. To be honest I wasn't 100% confident I could do this when I started, but it's turned out OK. It's not perfect by any means, and there are quite a few areas I would work on more if I had the time. Ideally I would have liked the walnut to be a little darker to provide more contrast. I might even have done the handles in oak and then fumed them. I would certainly put more oil on if I had time - it's only really had one good coat, so I hope it looks ok on the day.
I guess it's appropriate that it's only got one coat of oil on, as that means it's not quite "finished", and Kate was right all along...  [big grin]
Oh, forgot to add - it seems that underground soil pipe, whilst more resilient than overground pipe, still softens! Also, duct tape doesn't like steam too much either, though that too held up reasonably well. Here's the steam box after I'd finished:
[size=12pt]
Yep, in life and death they are saying that, but we still love them!  [smile]
Great result. I am sure she is proud of you, and so should you be proud.
Our thoughts continue to be with you.
Beautiful work on a noble project.  I pray the funeral begins the healing process for you and your family.
You never get over losing someone you love.  You just learn to live with it, day by day.
The good memories help more than anything.
A very personal and emotional project. One can see where your heart lies. I can only echo all the previous comments. May peace be with you and your loved ones.
I went up to the funeral home today to put in the walnut dominos that fix the lid in place.
Emotionally I've been OK through most of this build - I suppose I've just been thinking about the practicalities of building it rather than dwelling on what it's for - but seeing it in there & knowing Kate was actually inside it brought me to tears in a big way. Hammering those tenons into place was, for me, the metaphorical 'final nail in the coffin'.
Everything is done now:
I've got a fairly quiet weekend coming up now, with visits from various friends & family who are coming for the funeral on Monday.
You've done a very brave thing Jonny. I doubt I could have done what you did.
I wish I could say something useful or meaningful, but all I can really say is I'm thinking of you and it really makes me reflect on how I would probably feel in your circumstances.
I hope you can eventually move forward with happy memories and that the sadness you're obviously feeling eventually fades.
Kev
Kate would appreciate what you have done and been proud of you Jonathan . I am proud of you too. It take a special individual to do what you have  and to share it.
On Monday remember the best of times you had together and cherish those times.
What time is the funeral? I would like to know as I will stop what I am doing  and share some time with you .
John
John
+1
Regards
Rob.
Amazing job take care this weekend and I hope the funeral goes off as well as funerals can, I'm sure Kate would be so proud of what you have achieved.
