glass1 said:8/4 white oak ? On the rail that's 2 passes as max cut is 1 15/16" The ts55 just has small heuvos.
huskercrue said:Cutting 3/4" melamine with the stock blade. Saw will shut off momentarily and then start up again. Have had some instances where the breaker pops as well. I sent the saw in for service a couple months ago and still having the same problem.
Sounds like you have a few coils that are shorted in your armature. This can happen when it is wound and the insulation on the winding coils is not complete. Does it fluctuate in speed under no load? Is the motor housing getting warmer to the touch? If you have someone with a PAT tester, ask them to check the tool for you.huskercrue said:Yes, the house breaker. I don't have a festool vac, using a shop vac. When I sent it back for service they replaced a bunch of parts. The saw itself is drawing 13 amps continuously, and then the amps spike and the breaker blows.
