Bosch Track Saw Coming to Canada/US (Mafell Made)
ScotF said:
Cheese said:
ben_r_ said:
Will probably still stick with my TS 55 though since I am so invested in the Festool system and I have yet to feel a need for more power out of my TS 55.
And if you need a little more poop...just switch to an HKC thin kerf blade.  [smile]
I do not think you can run the thin kerf on the TS - I think it causes an issue with the riving knife. Maybe I am mistaken?
[member=44099]Cheese[/member]  [member=6605]ScotF[/member]
Tenryu makes a thin kerf blade for the TS55 that comes with it's own riving knife.
Mike A.
Cheese said:
Thanks [member=30413]mike_aa[/member] for that heads-up. That’s a great alternative if you need it. There’s a ton of stuff out there and it’s nigh to impossible to remember it all. That’s why this forum works so well.
That is awesome! Had no idea. I was at a store that carries Tenryu as I need a new blade for my TS75, but was not sure how much the kerf would be off - I really do not want to replace all my anti-splinter strips.
The USD price point of the Bosch doesn’t put it far off from the price of the TS 75.  One place where Festool kills it customers is the ridiculous over pricing of their tracks.
Great to see that the Bosch track saw is coming to the US with even better rails.
I have decided to sell most of my Festool and purchase alternative tools for the precise reason of exorbitantly high pricing even for some of the consumables, such as sanding pads.  I just needed a new pad for my Rotex, it was $50. In my opinion way too extreme when Bosch 1250 pad sells for around $12.
I will likely keep only the Domino and the CT22. May even sell the latter to replace with a Nilfisk.  I purchased most of my tools around 10 years ago when pricing, while still higher than other tools, was not as high as it is today. Even though I already own all the tools I wanted to own, I found the Rotex pad price truly insulting.  For me this is not about ability to afford, I can afford it all day long, it is about value and fairness.
Why would you have to replace the anti splinter strip on the rails if you used a thinner blade?  The blade, thick or thin, sits against the backstop on the saw arbor.  That is the inside.  That is also the edge of the ant splinter strip.  The rest of the blade, whether thick or thin, goes out from this inside edge.  There is no anti splinter strip to the outside of the inside edge.  Its just air out there.
I suppose you could have troubles if the overhang of the teeth is different.  The thick blade is 5mm thick.  Teeth overhang the edge 1mm.  Whereas on the thin blade the blade is 3mm thick.  And the teeth overhang 0.5mm.  Then it would not match up.  But if the thick blade is 5mm thick and the teeth overhang is 0.5mm.  And the thin blade is 3mm thick and the teeth overhang is 0.5mm.  Then all is perfect.  Anti splinter strip is just fine.
This is as logical as selling a car you own outright to buy a new car because it gets better gas mileage.
Sorry, but your statement does not make much sense as stated without further context.  In the car analogy, if the new car did not cost any more to buy than what the current car would sell for, it would make total sense, right?
It just so happens, in my case, I expect to spend about what I would get from selling my Festool tools I have to purchase the replacements.
JimH2 said:
FM_SC said:
I've decided to sell most of my Festool and purchase alternative tools for the precise reason of exorbitantly high pricing.
It makes a lot of sense.  If the new car uses half the gas and you drive a lot of miles, then the gas usage cost/savings will more than offset any difference in price between selling used and buying new.  If a new tool will allow you to earn twice as much profit, then it will likely pay to replace the old tool.  If the new tool costs one million and the old tool costs one dollar, then it won't make sense.  But if the old tool is ten thousand, and the new tool twenty thousand, and you can earn five thousand a year more, it makes sense to get the new tool.  After two years the new tool is 100% gain.
Cars suffer from massive depreciation much like most tools and a different saw won't cut any better or faster than another nor make you more money unless you are going from a handsaw to a tracksaw and not from a more expensive saw to a less expensive one. There is always opportunity cost associated with money and spending savings or taking on a new loan to subsidize a new car makes just about zero sense if your goal is to "save" money on gas and compromise on functionality (most likely size and usefulness). A decent example of this would be selling an F-150 that gets 15 MPG for one of the newer ones that can squeeze out over 20 MPG. You will "save" money on gas, but it will be a long time before you cover the spread, which in addition to the cash outlay there are registration fees in most states that are 3% and up and some states like mine have an annual property tax on cars that can be substantial.
SRSemenza said:
Or get four cordless track saws attach one to each wheel and use zero gas. Would only be able to choose forward or reverse though.  [wink]
You’d run out of battery power after 300 feet.  The 18 Volt systems just don’t have the guts required to do large projects.  The new Makita 36 (Dual 18 Volt) gets heavily critiqued for being unpowered.
Steven Owen said:
The 36v Makita get critiqued for being underpowered (unpowered)??? I've never heard that and I know many people using it. I have it and use it all the time. It's the most powerful cordless tracksaw and it has more power than most corded....until the batteries get depleted.
Thay said, 4 of those with 8 batteries should get you about 300 feet. Haha
Sent from my SM-G960U using Tapatalk
In my earlier Reply (#5) to this post I wrote that I was:
“A long time Festool TS 75 user/advocate - I’ve been looking for a “55” - For “day to day light work” - But have been a bit apprehensive after lately reading concerns about Festool’s TS 55’s being 'under-powered' (bogging down on some cuts)”.
Hence, I was seriously giving this coming Bosch TS 55 a look.
Yesterday, I “scored” a TS 55 REQ-F-Plus USA and FS-1400 Guide Rail (55") combo -
On Festool’s Recon Sale - At 75% of their New Price. Couldn’t pass it up.  [wink]
So... I’ll keep my beloved TS 75 "beast" - For “heavy duty” cutting - Thicker materials, extremely hard woods, and ripping.
And dedicate the “new” lighter TS 55 for cross cutting stuff up to 3/4” thick - Which has become the majority of my cutting.
My woodworking is done in my shop - So I’m “good to go” with corded tools (actually prefer ‘em).
I'm hoping that "covering my bases" with the two saws -
I'll alleviate my earlier FOG read "concerns about Festool’s TS 55’s being 'under-powered' (bogging down on some cuts)”.
I guess it’s like they say: “In for a dime - In for a dollar.”
Or... ln this case... 75 cents (on the dollar, that is).[smile]
I agree with Handyman, I've just replaced both my 240v ts55 and hkc55 with the 36v Makita it is that good.
I personally crosscut ironwood with no resistance that my 240v Kapex struggled more with.
Back on topic, I think best part of the Bosch/Mafell setup is the rail connector, much more accurate
The.Handyman said:
Steven Owen said:
The reviewers where passionate fans of the Festool cordless tracks saws.
After using the mafell rails, I will never go back to the Festool rails. I’m working on custom rail guides for my Festool routers.
So is there any good website to learn about what stuff Bosch has, that is learn more about their Festool similar woodworking tools.  Being in the US, the track stuff and so forth is basically unseen. You can really only find info about the low end stuff sold at Lower and such.  The Bosch websites look to general be awful (every page a pop up, can't get anywheres without constant pop up messages about stuff).  The non-US sites are just as bad and really don't have good navigation or any good way I have found of figuring out much on the tools.
Perhaps a google search for a Bosch forum would reveal some results.  Here is one that came up for me:  https://www.bosch-professional.com/gb/en/community/
