RKA said:
Eric, have you used your MFK for trimming the fastcap stuff? If you did, any thoughts? There was another thread recently where people were commenting that the fastcap adhesive was gumming up the bit and generally fouling up the dust collection because it was so sticky. I remember watching a video with you trimming edge banding with the MFK and it seemed to go pretty quickly/smoothly, but I don't remember you mentioning what kind of edge banding you were trimming.
Yeah, The first time I trimmed the Fastcap edge banding with the MFK it was nasty! I was trimming the black PVC banding. I played with the speed….didn't help out.
So then I did the same thing that RMW shared…..Apply the PVC banding, with a razor trim off all the excess banding then run the MFK to clean it up.
If I use the Fastcap PVC edge banding I don't bother with the MFK anymore. It's a great trim router, but for me, it's faster to use the Fastcap tools to trim the PVC banding.
Now in the video where I'm trimming the edge banding with the MFK….it's real wood edge banding on 18mm (3/4") plywood. The edge banding was 7/8" ( if I remember correctly).
In the last cabinet video of me ironing on the edge banding I'm applying the edge banding to 12mm (1/2") plywood. The drawer parts are small and the edge banding is 7/8" wide. I can't
use the MFK with the thin plywood and wide edge banding. The bearing guide on the MFK doesn't run along the board that needs to be trimmed. So if I wanted to use the MFK I would have
to rig up some kind of jig to hold the drawer piece. And the base that I would have used on the MFK is just as big or bigger then my drawer pieces. It just wasn't the proper tool for my task.
And, with so much excess edge banding over hanging the 12mm plywood and the router bit I use it would have left me with long strips of banding (above the router bit) that
could/would clog the dust port. I didn't want to buy 2 different sizes of edge banding for the project which is why I'm using such a wide edge banding on the 12mm plywood.
Hope that all makes some kind of sense….. [unsure]
Eric
