Stoli said:What did you use to set the router depth? Looks like a set of thickness gauges that attach to each other magnetically. Metric or imperial?
erock said:That would be the Fastcap Mag shims. The metric version. They are magnetic. 25mm total thickness with 2mm increments and the metal plate is 1mm thick.
Plus, they have holes spaced 32mm apart 37mm from the front edge….for quick marking of true 32 measurements. Also, the corners have different radius for quick marking if
you want to soften a corner of a board or something.….very cool little setup gauges.
http://www.fastcap.com/estore/pc/viewPrd.asp?idproduct=47246
Eric
erock said:I have all the base cabinets done.
Tim Raleigh said:erock said:I have all the base cabinets done.
Eric:
The finish on the doors look great.
Tim
Charlie Mac said:Eric,
I want some of whatever's in that cup. Apparently it causes one to happy dance. [eek]
Jeff Zanin said:The high-speed erock is great, I just don't understand why my projects take soooo much longer.
What is the bushing used at 0:53 to secure what appears to be a Kreg clamp?
Jeff
erock said:Jeff Zanin said:The high-speed erock is great, I just don't understand why my projects take soooo much longer.
Jeff
Jeff that's a bench dog. If you do a search here on the FOG you'll be able to find a couple members who make and sell them.
Eric
pmarcusm said:Hey Eric,
I had to show my wife your video of the cabinet building. She heard your music that you use when you are in high speed and thought I was watching some hoochy mamas dancing! I had to prove to her that is was the other think that makes men excited!
Thanks for the cool videos!!
Marcus
Scott B. said:Eric
Just checked out your most recent vid. Love the camera work. Cool to see how far your shop has come in the past few months. Keep up the good work!
