pingvinlakrits
- Oct 2, 2007
Moderator edit--- this topic was started in a different thread. I split it because it is really a different discussion.
I did not read through the entire thread but I would like to comment as I have tried the Carvex. I got to borrow one to try it out on the work site from my very generous Festool dealer.
To sum it up the disappointment is that it does not give a straight cut on thick material. Cutting up a few studs, 2x4 and 2x2 even with a new, correct, blade will not give a straight cut so prepping beams and studs is not a suitable task for this jig saw. Well, to be honest the PS300 Trion does not do it well neither, at least not good enough. At first he did not believe me but when I showed him he could not dismiss the problem. After a few weeks he started getting returns on the Carvex and the people that returned them opted for the PS300 instead.
After going through pretty most of the major player jigsaws on the market I could lay my hands on I must say the only one that does not disappoint is still the old Bosch GST85PE. I praised the Bosch GST135 but with time the steel/aluminium foot gets warped and causes the machine to wobble. On two out of three 135's I have seen the warped foot. A poor construction though the saw itself is good.
I had hopes up for the pricey and innovative Mafell P1cc and tried it out on a demo - even on the rail it would not cut a straight cut unless it had the incredibly expensive specialty blade fitted to it. With the specialty blade it was good but still not too impressive - on the slightly warped benchtop that Mafell brought it did not cut too well and failed to do a straight cut (!) and without the specialty blade in place it did even worse than the Bosch jigsaws on the same material. The Mafell cuts impressive circles but it is still not a tool for fine carpentry or a replacement for a circular saw. I have yet to see a jig saw that is. For cutting thicker material the ONLY jigsaw I trust at the moment is the Bosch saw, it always does well. It does not cut that fast - but as long as it gets it right I am in no hurry.
I was hoping the Carvex would impress me, as I hoped the Mafell would too - but what is the point of having an expensive tilting sole as an "option" when the regular "precision" sole still will not give you a straight cut?
Back to the drawing board and come up with something that works guys.
