MrToolJunkie
- Jul 6, 2009
I am really on the fence about ordering (preordering) the Centrotec Systainer. I get close to placing an order and then start debating with myself again. On one hand I really like the concept and some of the unique items that will only available in the set at the time it is released (and at a savings of ordering separates). I have held off buying any Centrotec bits and drivers waiting for the set. OTOH, I keep going back and forth over buying stuff that I do not see that I will use -- i.e. the hook driver -- while I am sure it is useful to others, I just do not see a need for this type of bit in my arsenal (or maybe I am missing something). I also do not use many slotted screws and do not see a need to use a drill to drive that type of screw (of course having the handle that accepts the bits allows this to be used as a hand screwdriver). Taking out some of the key components like the drill bits and a few of the driver bits that are available today, combining them with a Systainer and you are well on your way to the purchase price of this current offering.
I know that this is a limited quantity, limited time offer and that they will likely sell out quickly -- so obviously others have made the clear choice that it is worth it to them and have no regrets. But, $425 is $425 and that could buy another tool or be put towards something that I do not have (Kapex, Domino XL -- when it is released), etc...
I would appreciate hearing from the collective wisdom of fellow Foggers. I know in the end that only I can decide if it is right for me, but hearing Pros and Cons from others will help and some of you have purchased similar sets in the past and I assume that they have worked or not worked out as anticipated.
So -- can someone give me a push or pull me back? Thoughts, comments and advice is much appreciated.
Scot
Scot
