- Nov 17, 2011
Hi, all. I'm one of the authors of the article in question, and the editor of FWW. I think I can shed some light on our reasoning, etc. For starters I can assure you that advertising was not a consideration. We are well-known for our editorial integrity, and in fact lose advertising at times because of it. Our primary mission is to attract readers, and deliver the best magazine and website possible for passionate woodworkers.
I knew that leaving out the bags would be controversial, but here's why we did it (it's also explained in the article): They fill quickly, they are not really reusable (hard to empty), and they are relatively expensive. So while the Festool works wonderfully with its bags installed and acting as a prefilter, keeping the HEPA filter unclogged and flowing freely, we made a judgement call that for most woodworkers, the bags would prove to be a nuisance and a constant drain on the wallet and ultimately be discarded. Or they would hesitate to use the vac for general cleanup for fear of running through their bag supply too quickly.
Aside from these tough judgement calls, the other tough thing about head-to-head tool tests is that there are usually only one or two winners, while many of the tools would work just fine for most people. In this case, if you don't mind the expense of the bags, rock on. Festools vacs work wonderfully. But the Bosch that ended up being the winner because it lets you ditch its bags, and yet the filter remains unclogged, due to the vac's built-in filter shaker. That gives you much more capacity and zero bag expense.
Hope this helps explain things.
