jmbfestool
Maybe look at the Wagner compact same as the Kremlin.
They both do two types a suction tube or a hopper.
Or
Wagner have the pump upside down and have a hopper best I’ve seen least paint wastage.
Kremlin is just a hopper attachment so you still have a metal tube wasting paint.
I’ll attach pictures so you can see what I mean.
I don’t know how much spraying you will be doing but seen as you talk about HVLP
I assume not a lot so I would advice a hopper system.
You use a lot less paint with a hopper fed system less paint to prime and less paint for cleaning.
Down side to hopper is if your spraying a lot of paint constantly filling up hopper but most hoppers take 5 litres so I’m sure that’s enough for what your doing.
As you can see metal tube will sit paint which is paint you waste just to prime machine. It’s a lot if you only have a 5 litre tin to spray.
Wagner is the same
[attachimg=2]
Then Wagner do a compact one with hopper it’s upside down so no tube to waste paint.
[attachimg=3]
Oh forgot to mention the Wagner work at much higher pressures the compact one goes up to 320bar compared to Kremlin 90bar.
Or
Wagner is the same
[attachimg=2]
[attachimg=3]
