Kapex calibration
Kodi Crescent
I have a new Kapex I'm setting up.  I'm working on my left and right cut calibration.
I started out doing the 4 cut procedure in the Supplemental Manual, and after I did the calculation I received 0.03.
I worked on calibrating it and after I did the calibration I received a 0.017.
The ideal goal is to have a calculation of 0.0, but this isn't practical.
Is this good, or should I keep working on it?
I just did the bevel calibration.  Using the method and formula in the manual, I receive a calculation of 0.055.
Is this good, or should I work to improve this?
Are these calculations in degrees?  There are no units for the formulas.
I'm not really sure at which number I stopped; but I remember that, at a certain point, I made the cuts from the other side of the blade, and noticed that it got worse if I adjusted it further. ( So, if I wanted the cuts better from the left side the right side cuts would get worse)
