Not yet, its on my list of things to do. I was just asking how easy it was, that's all. Oh, and to finally post my first picture. I usually use my iPad at home when on the FOG and decided to try posting a picture at work today [wink]Shane Holland said:Have you followed the instructions for adjusting them? Page 28.
http://www.festoolusa.com/media/pdf/Kapex-KS120-Supplemental-Manual.pdf
Yes, I was locked into 0 [thanks] I also need to do the 4 cut method of making sure everytning is squared up because I think it could be off just a bit.skids said:OK, dumb question, but only ask because it's been a year as you mentioned.
Are you sure you were locked into 0 when you made that cut into the ZCI?
Don T said:I recently had to adjust my lasers. After adjusting the lasers when the saw is at rest the lasers line perfectly. When I bring the head down they skew to the side, is that normal.
My issue is to the right of the blade, the laser is off almost 1/8". I made the ZCI last night and the laser line to the right shows the issue well (that is why I posted it) I'm not saying that I expect the laser to be lined up perfectly down the entire length of the ZCI when the saw is in the up position. I'll make some adjustments and go from there...skids said:I gotta be honest, I am not sure the lasers are supposed to be in line with the entire cut line on your ZCI..I have one too, lasers are adjusted to the blade and I am able to sight my pencil marks just inside and take them (or not) when I make the cut.
Correct me if I am wrong, but after following the instructions in the manual it seems you just need to be concerned with the lines where the blade comes down into the workpiece correct? In other words should I care that the lasers run out a little far down the ZCI when the saw head is up and all the way back at rest?
Just want to make sure I am thinking about this the right way and the lasers should align where the blade kerfs only or the entire span it's able to cut? I have a similar problem after making a ZCI to Dan where the lasers run off a little. But where the blade is they are fine. Let me know if I am making no sense..
Rick where are you when we need you!!
SRSemenza said:Mine are right on through out the cut.
SRSemenza said:Sorry, while I am actually making the cut ..... I can watch the laser line on my mark while the blade is spinning and cutting as I push the saw through the cut.
I suggest going through the full calibration process very carefully. [thumbs up]
ericbuggeln said:What thickness material are you guys making ZCIs out of? Forgive me, I just got mine two hours ago and haven't had time to play with it, Eric
Hi Eric,ericbuggeln said:What thickness material are you guys making ZCIs out of? Forgive me, I just got mine two hours ago and haven't had time to play with it, Eric
