WoodWhisperer said:The hardware kit came from Richelieu. U can search online. They are all bout the same. The top hook was actually fabricated at a metal shop. The kits u buy come with a hook, it just didn't work out for this project. Be sitting down when u click on the price of those kits!!
Sean
mfisher said:WoodWhisperer said:The hardware kit came from Richelieu. U can search online. They are all bout the same. The top hook was actually fabricated at a metal shop. The kits u buy come with a hook, it just didn't work out for this project. Be sitting down when u click on the price of those kits!!
Sean
Fabricated.......that makes sense, I had searched every corner of the interwebs for those hooks. It is shocking how much the kits cost. The library I am building is for myself. I even dropped the floor two feet, making the ceilings 10' tall, all to justify getting a library ladder. Ha.
xuamox said:Amazing work! I looks beautiful. How did you finish the shelves? Did you spray them, and is that hard to do? What type of setup do you need in order to spray?
alfa said:What an excellent project.
Couple of questions:
- What happened to the carpet under the cabinets - did you cut it out or simply install over?
- What types of pins did you use for the shelves?
Thanks!
Alfa
SeanWoodWhisperer said:I made a jig to drill all the holes. I lost count but I think it was over 2000 holes!
Had something like 10 hours in just the holes.
WoodWhisperer said:Had a couple(80) shelves to build. Customer wouldn't the shelves the some thickness as the rails. Made them with 1/2" plywood with a spacer in the middle to make them a full 2" thick. Yes it sucked!!
