Brice Burrell
- Mar 13, 2007
promark747 said:Neil,
I am confused on how you are attaching the stop to your MFT/3. It seems as though those two aluminum pieces are too long. As you can see in the pic below, the holes on the stop are only about 12mm away from the channel where the feather key is. Would you mind clarifying? I assume you have the arm of the stop resting flat on the MFT/3 surface.
Thanks,
Brian
Brian, see posts #6 and #9 above.
