Looking for suggestions to hang a screen door
4nthony
Southern California
Hey all....
I recently built a screen door and have been puzzling out options to hang it. The door thickness is 30mm and I had originally planned to use a 3.5" hinge, but I'm now realizing that hinge will probably be too wide and the pin will protrude too far from the door.
I also noticed that for the door to sit flush with the stucco, the holes in the leaf align in a weird spot on the jamb and would be drilled half in wood and half into the stucco corner edging. I also don't know if I will be able to cut a mortise for the hinge.
Some options I've been considering:
  • Find an asymmetric hinge with a 2"+ leaf on the jamb side and a 1" leaf on the door side.
    • Ideally, this would put the jamb holes into wood and the pin just outside the stucco/edging.
    • Not sure if I can cut the mortise for the hinge or if I'd need to surface mount it.
  • Add a single piece of 18mm cedar to the hinge side of the jamb and mount the door to this piece.
    • Cut ~18mm off the hinge side of the door, or...
    • Cut ~9mm off each side to balance out the stiles but this aligns the door slightly off center
  • Build a jamb for the screen door and mount it inside the existing jamb
    • Need to cut ~22mm off each stile and top rail to maintain a ~2mm gap
    • The door is centered but there are now narrower stiles
    • Space between the exterior door handle and the new jamb will be very tight. There's clearance, it's just tight.
I do not want to use exterior surface mount hinges that would require me to drill into the stucco (bottom picture).
What would you do?
EDIT: I put this into the Materials subforum as I was originally looking for hinge advice, but as I typed, it morphed into something different. Maybe it should be moved to the home improvement forum?
Thanks and cheers,
Anthony
I don't want this type of hinge
You could also just get some hole-less butt hinges and drill where you want the holes?
Well, screen doors really call out for spring-loaded hinges.
Maybe bronze would suit your esthetic? And while you are at it, bronze screen mesh is superior to aluminum or fiberglass and looks rich.
I lived on the north shore of Long Island, and many of the multimillion dollar shoreside homes had all bronze hardware and screens. They looked very rich. Pricey, but you don’t need much of it so it si manageable.
And while you are at it, a mechanical twist-to-ring door bell in bronze is classy.
Knife/pivot hinges top and bottom? There's also those surface mount type hinges that are asymmetrical when unfolded. This might avoid the issues with non-aligned edges of the jamb and door.
  • Pivots-Offset-Pivot-Hinges-Door-Commercial-Door-Hinge-Set-Pivots-Offset-Pivot.webp
Nice screen door.
Maybe use SOSS hinges?
I love SOSS hinges but that would be even harder to mortise into the edging and stucco behind it. This door opening used to be a window and the stucco is an inch or so thick. More or less right where I need to mount the hinge.
That's actually not a bad idea. I could even try and cut down the leaf on a larger hinge to fit the smaller door.
I looked at some spring loaded hinges but not sure about their bulk. The house is white with grey and black accents so I don't think bronze would match. I like the idea of bronze screen, not for this house, but perhaps for the house I'm currently living in. This is a door leading out to the backyard so no door bell is required but might be a fun idea if I put a door on the main entry.
The knife/pivot hinge is an interesting idea. I'll have to explore that a bit more.
The asym hinge is what I was looking for, but I didn't find one with a big enough difference.
Otherwise...
any thoughts on simply adding the partial jamb to the hinge side or is that kinda weird?
Thanks all!
I'd go with the hole-less hinges, or as you suggest cutting down a larger hinge recessed a little further back to secure it as probably the easiest and best options given the flywire is pretty thick at 30mm.
Not a big fan of the spring loaded hinges myself, and if the door was extruded aluminium the knife hinges would be fine, but I wouldn't use them on a tall timber door, and the good ones suitable for the size and weight would be pretty expensive I'd think, but the door is then completely unsupported in the middle.
I think it'd be a bummer to have to trim .87" or whatever from the left and right stiles of the door to accommodate a partial jamb, the proportions of the door look pretty good as they are currently.
Is there no way to remove the existing stop on the hinge side of the door and replace it with a wider one?
As I have 45 years of commercial door service, sales and repair, I would use a Roton continuous hinge as they are available for 1 3/8” depth and would only decrease the door width by 3/16”
Agreed. I don't really want to cut it either. I'm not sure what you mean by "remove the existing stop on the hinge side and replace it with a wider one?"
This non-mortise hinge might work for you using only two of the four screw holes in each leaf. Three or four hinges should carry the weight of the door.
That could be an option as well. Maybe add a couple more holes.
KEILEOHO_12_PCS_4_x_3_Inches_Black_Door_Hinges_Non-Mortise_Stainless_Steel_Door_Hinges_with_Mounting_Hardware_Brushed_Surface_2025-07-19_12-36-33.png
That's an interesting hinge. Pricey, but a cool look. Need to find more specs on the leaf sizing and if they come with and without holes.
Guessing it is easily cut to length on the miter saw?
Hager_-_48046_780-112_Series_Aluminum_Standard_Duty_Fire_Rated_Roton_Continuous_Geared_Hinges_Concealed_Leaf_Clear_Anodized__2025-07-19_12-44-59.png
The Roton hinge looks like a good call as well.
Ferguson Home lists 4 different geared continuous hinges, ranging from $133.00 to $203.00. The cheapest of the bunch is rated for a 600 pound door! A bit much for a screen door.
I don’t understand the advantages of a geared door hinge. But it looks neat.
And this site lists the advantages of the geared hinges, but they don’t seem like an advantage for a screen door.
A continuous geared hinge is typically used in applications where there is a need for a durable and long-lasting hinge solution that can withstand heavy use and high traffic. These types of hinges are commonly used in commercial and industrial settings, such as hospitals, schools, airports, and government buildings.
Continuous geared hinges are designed to provide smooth and quiet operation over the life of the door, while also distributing the weight of the door evenly across the hinge. This can help to prevent damage to the door frame and surrounding structure, as well as reduce the need for maintenance and repairs.
As an aside, I have also built screen doors. The first one I built from 1-1/4” thick pine and I used tenons (tenoning machine, not a Domino). The second one I built using 1/2” x 3” dowels. Both have been up for about 5 years and show no stress at the joints. Pine was acceptable as I have a 6’ cover over both doors and they never get wet.
Screen doors, unlike conventional doors, seem to not require really fancy joinery for strength. I used removable screens for both. The first one used butt joints and plastic joiners. The second one uses mitered joints and hidden aluminum joiners. In my opinion the mitered ones look much better. My chop saw would have left large burrs. I used a picture framing saw to make the miters and those were fine.
