Rick Herrick
- Feb 7, 2020
I have two of these patio doors on the back of the house. Each consists of one stationary side and one in-swinging door. Each has differing levels of rot at the bottom of each jamb. The sides should be pretty routine. The center stanchion/stile is another thing. It looks like a piece that is 2.5" wide and 1.75" deep, with a piece of molding (2" by 3/4") over the top. I picked up a few things from the big box stores. Trying to anticipate what I might run into. When I looked at it closer, it seemed the center section might simply be two regular jamb sides with the front trim to cover the space in between. On the door side, the rot is also in the piece of the jamb that the door touches. I guess I can get that out but the other side, the one with the stationary panel, won't be as easy. Has anyone dealt with this set up before? Any suggestions ?
