Show how you store your track saw guide rails
demographic said:
I made a box using 12mm plywood as spacers which allows the rail to slide into the box and 6mm between eaxk rail and on the outside.
Still got to add another layer so it carries three rails and attach it to inside of my van. Oh and when its done I'll do a cut so all the edges are tidied up.
I used a holecutter to make holes so the rails dont get stuck in there and I can get my fingers in as needed.
That's a nice solution for someone who has to take their rails on the road. Do you plan to add a Velcro strap or other closure on the open end to prevent the rails from sliding out during transit or has that nor been an issue so far.
With the awsome G forces experienced within my Toyota Hiace van, erm... I cant say its been an issue.
Its a snug fit so they don't really move about.
In my van taken last summer. I've since drilled a ¼" hole and put a dowel through the rail holes to hold the rails in place.
I was thinking of maybe using a variation on that (much wider slot though) to hold my rail box thing, that way I can remove the entire box and carry my rails onto site. It doesn't even need to be full length, just the ends to hold the box in place.
Some sites are better than others and on some I can trust the people around me, thats not always the case and some people are denser than others.
The rail bags Festool supplies only seem capable of keeping dust and paint off the rails whilst giving Festool a massive advertising space so if I can't make something better myself I might as well just pack my tools up and give in. I do own one of the bags but thats cos it was cheaper to buy thana case for my air rifle [big grin]
After seeing your box I was thinking of doing exactly what you are suggesting. Doubt I'll ever take the box out but having the option is nice.
Mine was made on the fly with some extra solid bamboo counter scraps. Until I have a longer rail and time I don't foresee me building anything different but now I have a direction.
For travel, I use a product called”sport tube” Originally made for the snow ski community,  I switch back and forth from my spear fishing gear and rails.
I can put multiple rails and a batterley connector. And it has wheels.
Sporttube.com
Cheers, Charlie
Sent from my iPhone using Tapatalk Pro
Mines not exactly proceeding at a pace, it depends on what offcuts I get on site and having a day when I've  got some spare time to glue and screw another layer on. Plus its not tidy yet, I'll neaten it up when the last layer for the 1080 rail is on. Forgot to mention but I also left a bit out of the end just in case I got one stuck and needed to poke it out with a half inch ply ripping.
They come out ok though, just enough resistance so they  zidon't slide about all the time but I wasn't sure at first.
The rails are 1400mm long so the box goes behind the bulkhead across the back of my van..
I plan on making a box up for my HKC FSK420 crosscut rail but I'll make the box up then cut it in half (old joiners toolbox style) then add hinges so it opens up like a clamshell. That way I can maybe fit some other related items in the box.
Got some bits of wood kicking about but need some more 6mm ply as well.
I'll get around to it at some point but there's also something that Ive been making for my 1800 level, I could do with adding something for my long Trend hinge jig so they arent clattering about in the back of the van.
I don't have much space and I also put motorbikes in there sometimes, plus I sometimes sleep in the back if I go to mates outdoor parties so its all got to be fairly modular.
Sporttube.com
Cheers, Charlie
Can you check that link? It did not look like a products type site.
When mobile, mine are in the holdall, when in the workshop, they are hung on meat hooks, that go into screw in eyelets.
They are perfectly safe, and easy to remove and replace onto the hooks.
Sporttube.com
Cheers, Charlie
Sportube.com
Try that
Thanks, Charlie
I keep a couple tracks up on the ceiling in my work trailer. They're well supported, have never slid out and in case the short one goes in first there is a groove cut in the bottom so you can  slide it out no problem. [attachimg=1][attachimg=2]
I also have chosen to hang my track rails on a wall in my little shop.  I have 10'-6" clearance below the roof trusses (no ceiling) so it was easy to install some screws into the 5/8" plywood siding and hang the rails out of the way.  There is no deflection even on the 10 foot rail when using it.
I simply nailed in some birch ply strips on the wall, and tracks sit on them with foam cushion, peacefully, with some help of the toggle clamps ;-)
Michael Kellough said:
[member=66983]gvega9889@gmail.com[/member]  You don’t have enough clamps  [wink]
I can see a couple of bare patches of wall in the middle.
I agree!  Still buying.  What I really need though is more Festools.
