Leland,
As of now I haven't heard of any failures - even after being served alcohol - [big grin]
Insight into my method of madness? OK.
First, this experiment was designed to foster goodwill and spur enthusiasm with the members here and serve as an reason to experiment with computer software in a useful manner.
The labels are a waterproof polyester label printable by laser printer purchased from
www.onlinelabels.com You can order a single sheet if you wish. They are actually labels commonly used for wine bottles.
The size ( 2 in x 5 in) was smaller than the original labels so as to maximize yield from an 8.5 in x 11 in sheet. The reduced amount of information on the labels allowed for larger images and print versus the originals. I chose white because I felt that the colors would show up better.
The images were mostly scanned from the catalog and then doctored using Photoshop. Some photos, including Ferraris, Bosch, Fein, and others were screen captured and then doctored. The layout was done in Adobe Illustrator. I have saved all the images and files.
Some members had special requests such as company name being added. I was more than happy to oblige.
Printing was done on an HP Color Laserjet 3600 so that they would not be affected by moisture.
These labels were sent to all regions of the US, to Canada, and also Australia.
Since this experiment I have located another source that has a truly permanent label that will achieve a UL listing for longevity outdoors. I also have a sample of a label here that is used on diplomatic pouches that is virtually indestructible.
That is really all that I can say. It was fun. Would I do it again. Heck yes.
I have stayed away from the label printers because they have a narrow range of label availability, and the consumable cost is high. I have a smaller Brother printer that will make labels that stay on well, but just wanted to go big.
I probably told you more than you cared to know - sorry.
