The fastest way to drill 32mm holes without LR 32-SYS
Mike35x95x1
No LR 32-SYS? No problem!
I created quite simple jig to make 32mm holes with OF1010 only with KR 10D-10,8 and  8mm plywood. It’s 120cm long but you can make as long as you need.
It’s really fast, precise and cheap.
Take care
Mike
DIYer from Europe (TS55, KS60, DF500, OF1010, FS1400, FS-WA/90, FS-PA-VL)
I did the same with parf mk II (it can do 20mm holes with 32mm spacings). It comes with 3 3mm alignment pins included so I drilled pin holes for common distances from long and short edge for very quick alignment, just need to clamp the thing. Also the first hole is 5mm so that a 5mm shelf pin can be used for extension when longer row of holes is required than the jig length.
