Hey folks,
Just spent a full weekend with the new toy, and have a little question. FWIW, I have not verified proper alignment or tuned the saw, since I wanted to play a bit before getting "serious"
That said, I noticed that when I plunged or retracted the saw into MDF, it left slight saw marks. By "slight," I mean they could absolutely be sanded away without much effort, but they were definitely noticeable compared to the nearly polished look of the rest of the cut. When starting a cut with the saw fully plunged before contacting the material (and only retracting it once the blade was completely clear of the material), the entire cut had that polished look. That method seemed to be totally consistent in providing an absolutely beautiful edge, but it's a little tricky (impossible) to achieve that in a 49" wide piece of MDF with a 55" guide rail.
Is this to be expected, or is it indicative of an alignment or technique issue? It's a minor annoyance, and I could always join another small section of guide rail to provide the extra length for wide crosscuts... but I'm just looking for thoughts before I spend a ton of time trying to chase the perfect setup.
My plunge and retract technique is one handed, I'm not using my left hand on the other handle because I felt like that would aggravate the issue.
Thanks!
mike
Thanks!
mike
