bertv
Coen said:Still the same crappy construction on the parallel fence. [unsure]
Coen said:It's never forced to move the same on both ends. Seems a €800 Dewalt (including the parallel fence) is more accurate on that part than the Festool (which sells separate for €300). My brother asked me about a table saw, and I advised him to look beyond a CS 50 (which I use). The CS 50 table isn't even flat, the fence isn't perpendicular to the table, the table is tilted downward closer to the saw... meh. And everything seems to be just not stiff enough. Eg cutting plates with the sliding table (492100) doesn't seem to give more repeat accuracy than just measuring it out and cutting with TS55 and rail.
Honestly, I think that is a shame.
FestitaMakool said:[member=5277]Alex[/member] - That’s multiplying into a huuge amount of Belgian waffles! With Nutella of course! [tongue]
No I had purchased a Batterley insert awhile ago and after a quick tuneup, I installed it.FestitaMakool said:[member=5277]Alex[/member] - That’s multiplying into a huuge amount of Belgian waffles! With Nutella of course! [tongue]
[member=9356]pettyconstruction[/member] - I believe the UG cart without wings are 10kg’s or approximately 22 Pounds
Complete with wings it’s about 21kg’s or 46 pounds.
Edit: I just noticed; did your Kapex come with zero clearance insert? Mine have clearance to all extreme bevel angles. European that is.
ART at WORK said:I just got the new FS WA/90. A pricy bit of Aliminium, and the only difference is no blue Anodising and a green piece of Rubber on the TSO clip. It was a lot cheaper for me to get this in Germany than to import the TSO original from the States.
Will give it a test run tomorrow.
