Bob Marino
- Jan 16, 2007
Michael Kellough said:Is it true that the Domino doesn't have a straight drilling function?
Michael,
Correct, it is set to make different size oval mortises, not round drill hole.
Bob
tvgordon said:I was wondering if it was possible to make the tenons or do they have to be purchased? I've made loose tenons before but I wasn't sure if the Festool tenons were compressed like a biscuit. Tom.
bill-e said:Bob, is there any functional purpose for the markings on the dominos?
John Russell said:I am not the most imaginative wood worker, so I work with what I have. I am interested in doing a variety of furniture and outdoor landscape structure projects (pergolas, decorative gates, etc...) and joinery is one of the things I am least informed about. I use an FMT for M&T for face frames and other projects, but I am curious about example applications for the Domino -- some information about the range of applications would help me to understand if it would be a useful tool for me.
John Stevens said:I ask these questions because Lamello sells glue applicators that make it fast and easy to apply glue to a biscuit joint with no squeeze-out:
1. What's the fastest way to apply glue to the mortises and dominos?
2. Is it possible to get a strong joint without applying so much glue that it squeezes out?
3. What sort of glue applicators and other tools (e.g., acid brushes) work best for glue application?
Les Spencer said:John Russell said:I am not the most imaginative wood worker, so I work with what I have. I am interested in doing a variety of furniture and outdoor landscape structure projects (pergolas, decorative gates, etc...) and joinery is one of the things I am least informed about. I use an FMT for M&T for face frames and other projects, but I am curious about example applications for the Domino -- some information about the range of applications would help me to understand if it would be a useful tool for me.
John,
Take a look at these links:
http://bobmarinosbesttools.com/
[url]http://www.mcfeelys.com/festool/product/574258
Both have lots of info. Make sure you page down on both.
Les (near Indy)
Jim Dailey said:Jerry,
Your explanation was as usual very well written to convey a good mental image. However I didn't follow what your where saying in this sentence;
"I regularly cut an 8mm Domino inside a 10mm traditional M & T joint when assembling R, S & P components."
Could you clarify for my thick head this sentence.
Thanks, jim
Dave Ronyak said:Last evening I received my issue of Fine Woodworking containing an article evaluating Domino machine. Although the author credited Domino with being a major innovation that is likely to change the way many work on many projects, the author also asserted that Domino joints will be too weak for use in the joints of a dining table, because the tenons are too small. I don't understand that author's reasoning, which I think overlooked the fact that multiple Domino joints can be used at each junction of an apron to a leg. In all dining tables I am familiar with the top extends over the legs as well as the apron members and any intermediate stretchers spanning across the aprons. Therefore the primary static load (vertically downward) and is supported directly by the legs in combination with the apron members and through their joints to the legs. Any side load, such as when pushing away from the table, or moving the table, will be concentrated in the joints of the aprons to the legs, but multiple Domino tenons could be used to somewhat distribute that load. Festool's online demos contain illustrations indicating that a staircase can be quickly made using Domino; that surely requires confidence in the strength of the joints, as does using them to make a chair. I have used multiple dowels and corner braces for table joints in the past and have never experienced any looseness or failure (some are >30 years old and still in daily use). I would like to know the opinions/experiences of other more experienced woodworkers and furniture makers than myself regarding the limitations of Domino joints. Someone has already pointed out that a Domino machine could be used to machine wider mortises to be fitted with shopmade tenons. The only limitation would be the depth of those mortises.
