Cheese
I'm in with Ron on this one...any amount of space you can free up will be a huge bonus round. I have a small 30" x 60" workbench that I work off of. It's in the basement and the space is tight. There's a Vac Sys on one end and a 60# vise on the other. While they can both be swapped end for end, it's still a tight fit. There's also a myriad of tools and items that seem to just naturally relocate themselves to the middle of the bench.
So I decided to make an extension wing for the work bench. It's comprised of 3 pieces of 80/20 extruded rail and it takes literally, 2 minutes to set up. All the frame members also store easily underneath the work bench. It's used only for those times when I need more real estate to finish a project.
Is there an area where you can mount a single horizontal run of 80/20? If so, the extended wing concept becomes an extremely stable support base, more so than the MFT which just kind of moves and shakes as it is want to do. I never really warmed up to a $700 table that shakes, rattles & rolls when you use it.
