MFT - Cut the top or not
When sawing do you use your MFT top as the backer board or not
  • I use the MFT top as the backer board
    Votes: 52 78.8%
  • I used a separate backer board to protect the MFT top
    Votes: 12 18.2%
    Votes: 2 3.0%
  • Total voters
    66
I cut into the top but only where the rail is, more or less. When it gets a little too chewed up, I'm thinking I'll try some epoxy filler or route a dado and glue in a wood strip to see if i can get a little more life from that side.
I'd like to keep the surface in as good of condition as possible so I can have a decently flat surface when I need it. However, I'm not sure how flat it will be long term. I have slightly raised rough spots where sweaty arms touched the surface.
