GarryMartin
- Jun 11, 2011
You should be able to get the ghist...
- a simple right-angle close-off parts to the whole complex free-form shapes, ranging from: arches, beams, convex and concave shapes
- interior arches made of 50 mm rádiusztól, the external form is up to 25 mm radius may block
- Shut off all the classic design can be processed quickly and easily - from the tree and the whole muanyagtól melamine - In view of the current material, 18 to 65 mm height and 0.5 to 3.0 mm thickness
- thermally decoupled glue unit provides quick heat-up Time
- Special Dosage Chemical Anchor System: comfortable and easy recharging the color change, the exact amount you need to melt adhesives
- 2-speed, speed setting, for example. the degree of the two straight parts by closure
- Temperature control: two preset temperature, the more freely adjustable to suit your needs
