The leftover 'systainer port'
stvrowe
Needing more Festool systainer storage, I built this out of leftover materials from other projects.  I also used salvaged baltic birch for the drawers and casters from an old router table.  The side and top materials are 3/4" two sided melamine and the back is 1/4 melamine (both mdf core).  I used dowel screws from McFeely's to assemble the case.  Alignment was used with a domino at each corner that really made drilling the dowel holes and assembly easy.  System holes were drilled with the LR-32 system and an OF1400 router.  I did the entire length for adjustability should future needs dictate.  It is nearly dimensionally identical to the Festool systainer port (only difference is 10mm narrower).  The only thing I didn't have on hand were the carriage bolts for the casters which cost me $2.43 including tax.
Steve      real nice sysport setup. I like the adjustability with the shelves, great job
Sal
Very cool that is the same height as the Festool Sysport.  [smile]
I need to build some sustainer ports and really like your adjustable shelves. What kind of drawer slides did you use that use the 32mm system?
Tom,
I used Custom Service Hardware 350mm full extension slides.  They do have holes for the 32mm system.
Steve
Steve,
I don't suppose you would have a part number for the slides?  I looked at their website and they have several 350mm full extension slides, but none list that they are made to work with the 32mm system.
Thanks,
Tom,
The P/N is
Item: 39.1150.14
Description: Slide, 350mm [13.78"] Full Extension Bright Zinc,15 sets/case
The description doesn't say 32mm compatable but they are.
Steve
Steve Rowe said:
Tom,
The P/N is
Item: 39.1150.14
Steve
Steve,
I went to the site and used the above number. I couldn't find it. Can you post a link to the product.
Cheers
Steve
Trying to challenge my computer skills again?  [laughing] I have not been able to get the link to work.
Use the cshardware.com search for 39.1150.14.  Be sure to click the button for search by Item Number and not the description.  The item should pop right up.
Steve
Steve,
Don't feel bad - that link wouldn't work for anyone.
If you go to that website, the search function is found by clicking on the shopping button.  Here is a link :
CSHardware
an image of that page:
[attachimg=#]
I found it today.  You can't us the "." after the last number or it can't find it.
Cheers,
Steve
I added the '.' to end the sentence.  Oh well, glad you found it.
Steve
I enjoy using cshardware, their customer service is excellent.  The website however, can be nightmare to find things sometimes, so don't feel bad.
Jon
Jon
Plus one on that Jon.  They've added Blum products in the last year and I've found they're prices to be very reasonable.
Steve,
I was about to order some screws for the drawer slides but wasn't confident on what to order.
I was going to buy the metric screws designed to fit into the 5mm holes of the 32mm system when I noticed that the holes in the slide for the drawers were smaller than 5mm.  So did you use the #8 drawer slide screws for everything or use them just for the drawers and the metric screws for the sides?
I know it has been several months since you started this topic but I'm a little slow  [tongue].  I have the slides and am finishing the 30 drawers to hold the systainers.  I wish I wouldn't have waited so long to build these, I have a small shop so I have to finish the drawers in batches.
Thanks for your help,
