Mario Turcot
- Nov 26, 2017
And some more updates
Stabilizers, the top is floating on the base and the stabilizers ensure the top do not move when I want to move away the whole table. The black spacers are adjustable feet up side down giving the ability to level the top if the floor is not even. I have about 3/4" play. The top alone is about 150lbs it's made of 2 sheets of 12mm 1 sheet of 18mm and one sheet of 15mm for the torsion part. Sheets are all Baltic Birch 60" x 60". The overall size of the top is 42 1/2" x 58" with an overhang of 2" on each side.
Time to put down the top onto the base. Some round over and sanding required.
[attachimg=2]
Front side, two drawers. One to hold the Vac-Sys pump & accessories and one to store the Vac-Sys bases. There will be a power strip on each side and a switch to activate the Vac-Sys pump. I still have to figure out the Vac-Sys pipes but everything will be on quick connect for fast removal.
[attachimg=3]
Left side, plan is to store the DF500 and the small dominos. There is also a bin for mini systainers for common screws etc..
[attachimg=4]
Right side, plan is to store the DF700 and the large dominos. Again more mini systainers. The central opening you see here is unknown [eek]
[attachimg=5]
Back side, large/thin drawers to store hardwares. That side face the table saw when used as outfeed table.
[attachimg=6]
Round over on all corners. the edge is made of hard maple. Next thing to do on the top is a good sanding and a coat of sealer.
[attachimg=7]
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
[attachimg=6]
[attachimg=7]
