Mario Turcot
- Nov 26, 2017
UPDATE
I have the torsion box done. I used 12mm BB ply on both sides.
[Pict coming tonight]
I am now at adding two t-track at the front
to hold the SYS-VAC system. I will add another layer of 18mm BB ply on the top only. That way the t-tracks will be shy of 1/16. the first t-track will be flush to the edge to add vertical clamping capability. The torsion box will sit on a rolling cabinet similar to Guy's cart
cart
Since it's a rolling assembly table and I made it specifically flat, I want to be able to micro adjust the top for when I move it. So far I found those
To adjust from the top. I was also thinking about a threaded rod and knobs mechanism.
Any idea what I could use? It need to be able to support ~400lbs
cart
