Maybe I'm missing something here? If you are talking about a beveled 45 degrees, this would not get any better or worse as you proceed down the run (e.g. 8 inches), would it? OTOH, if you are talking about a cross-cut, then the adjustment would be between the guide rail and the fence, not the internal settings on the saw itself . . . ?
Going back to the saw itself, however, I agree with Tinker, the angles on my TS-55 are virtually impossible to set accurately using the bevel guide on the saw.
While we're on the subject, in a previous comparison of the 55 and 75 saws, someone mentioned that the 75 is top-heavy when set on a 45-deg bevel, whereas the 55 was not. Does someone have a TS-55 different from mine? When I set the saw on 45 deg it falls right over, whether sitting on the MFT alone, or on the guide rail.
Given the design of the baseplate and the enclosed blade, I feel pretty comfortable placing my left hand on the plate to hold it down to the guide rail as I make my cut. However, with any flex in the guide rail, or with any change in pressure with the left hand, the resulting bevel is going to deviate from 45 degrees.
At this point I can certainly see the advantages of a sliding compound miter saw (as recommended elsewhere) for cross-cutting bevels. My second project with the TS-55 was adding oak trim to a laminate kitchen counter. It took me hours to get the corner bevels worked out. Some were 45-deg. On others I first cut a 1" 45-deg corner on the counter top, and wrapped it with a 1-inch piece of trim. These pieces required 22.5 deg angle to connect the front trim with the corner piece, and then the corner piece with the side trim.
Cutting a 1-inch length of oak trim with 22.5-deg bevels on each end was a bit of a challenge to say the least. At the time I was attributing this to my ignorance. Now I'm simply amazed I was able to accomplish this at all, but at the time I didn't realize I probably shouldn't have been doing it this way at all?!
Ed
