James Watriss
- Mar 4, 2008
I dunno, Frank. I bet Festool, or someone else, could make a piece that mates directly to the current extrusions all the way to fitting the slots for the foam rubber strips, and wide enough that it would maintain one-piece accuracy without needing to be made of one piece. Instead of simple T-track nuts in the track on the underside, have a solid steel bar made that is made of stock that's specifically shaped to completely fill that slot, and slides in from the end. Make sure that piece also extends far enough along the rail that it would help to hold the 90 in place when the screws through the fence are installed, with no slop whatsoever. And add a big gratuitous bolt through the hang hole. BAM. Done. As an accessory, add in PSA plastic tape to help the rail slide, to replace the foam rubber and help the rail slide better.
If you really want to get kinky, you could make it compatible with the bridges from the parallel guides for quick-shooting repetitive short cross cuts. Not really concerned about that one, since the original paradigm behind this idea was a sliding rail for quick, from-the-hip shooting, but the thought crossed my mind, so I figured I'd throw it out there.
