woodguy7 said:Im with Dean, its usually tilled then the bath set in. That being said, i do like the look of your bath with the near flush ledge. But then again, wait till you have a couple of kids in there splashing water everywhere, because they will [big grin] [poke] Hope you have plenty of silicone arount that tv [big grin]
woodguy7 said:Oh but you dont know the damage kids can do [big grin] & i did correct my mistake if you care to read above [tongue]
jmbfestool;142199 said:The shower tray was also fitted before i tiled the floor so I tiled up to the shower tray to make it look more slim lined.
I have never seen any one tile then fit a bath thinking about it. You always fit baths then tile it well i have ripped out a few baths i had to cut them through the middle to get them out so not to cause damage to the tiles which were trapping the bath in.
Jmb
jmbfestool said:No the other rooms are finished what you trying to say? Joking! Lol
No the entire housenhas been gutted! I removed EVERY wall upstairs they where all blocks Walls! So very heavy on the floors as they where just built onto the floor. Also I can not hide pipes and cables easily in single block walls. So I rearanged some of the layout made the bathroom bigger as it use to be a bathroom with seperate toilet so now it's all one. Its all stud Walls upstairs. I have made the little bedroom bigger by reducing the cuboard space as that was far to big cus it had the water tank in der as well but I have fitted a new combo boiler in the loft saving space.
It has had loads of work done I had to redo the valleys on the roof new facia barge board sofet guttering. I took down the flat roof on the extension and put a pitched roof on it. Took down few Walls on the ground floor and supported the floor above and put some studding up to create a larger hall and so I could have a down stairs toilet i hate not having a down stairs toilet so I had to fit one some where. I removed all the old windows and doors I made a window into French doors and blocked up a door made it into a large window. I removed ALL concrete BOOT lintels and replaced them with catnic lintels.
Dab boarded and plaster boarded every room so all rooms have been redone new wireing plumbing. All rooms have been plastered!
Loads to do still did some digging in the garden with a mini digger had some fun for a week! Lol still alot to do Outside.
Jmb
Guy Ashley said:I think they are the same parent company who do Moben kitchens and always sub the work out.
I hear they pay very poor rates and consequently only get fitters that cant get work anywhere else.
I suppose if that is right then the tilers are of a similar breed.
joiner1970 said:jmbfestool;142199 said:The shower tray was also fitted before i tiled the floor so I tiled up to the shower tray to make it look more slim lined.
Jmb
Hi jmb,
No the way it should be done is that you tile the top of the ply box then you can lower the bath down into the hole and the rim of the bath should sit slightly off the tiles supported by its legs not the tiles. This leaves you with a neat joint under the bath rim which is sealed with silicone. Then once the bath is connected and tested the front of the ply can be tiled, usually an access panel is left ie one tile is stuck with silicone so it can be removed.
Ive done a few built in baths in the 20+ years ive been a joiner I hope I know what im doing lol.
Chris
joiner1970 said:JMB,
jmbfestool said:joiner1970 said:JMB,
Well you see a few reasons!
1. The bath only cost me 40quid from BnQ because it was damaged! Well gues where the damage was! On the side I have against the wall!
2. I don't like the curve I actually hate it so having it It in the corner kinda hides it but 40quid is nothing as the bath was worth £300 or more. It's a very deep bath. I have sunk the bath into the floor otherwise you would have to try and hurdle over the bath.
Well I always seen tiles go onto the bath better water seal so are you saying should I of tiled the front top of the bath first then put the bath on to of the tiles i then tile the back wall so the tiles go on top of the bath
Deansocial said:i normlly fit the bath test it all then box it in leaving the correct gap for a tile to slide under the rim of the bath. I try not to use ply either as i had a delaming issue on a job(nothing major) so always use a tile backing board now for piece of mind and i believe it is a much better job
joiner1970 said:Deansocial said:i normlly fit the bath test it all then box it in leaving the correct gap for a tile to slide under the rim of the bath. I try not to use ply either as i had a delaming issue on a job(nothing major) so always use a tile backing board now for piece of mind and i believe it is a much better job
Yeahj thats another way I have done them as well I dont get involved too much I just do the boxing for the plumber. I can plumb and I can tile very well if I do say so myself but when Im on a new build we have plumbers and tilers so I dont need to do any of that. Regarding the plywood we have never had a problem with delaminating but a lot of the time we do use wedi board or cement board as it is a better job.
joiner1970 said:Guy Ashley said:I think they are the same parent company who do Moben kitchens and always sub the work out.
Yeah and Sharpes bedrooms another bunch of rip off merchants.
I felt sick when she said what she was paying for it. Sadly she would have used us but she didnt know us when she booked Dolphin. They tried to get her to book the kitchen in with them as well but luckily for me she didnt. I finished her kitchen Friday, built her a new master bedroom made up from two beds knocked into one with an entertainment wall, plasma tv etc, walk in wardrobe to do and they want us to fit out their new offices at the company they own. So not a bad little job [big grin]
