thudchkr
- Dec 13, 2007
I use a surge arrestor because I have a DVR lathe in addition to the Voyager drill press. Where it gets more fun is when you want to run the unit on 220V, as I do for both units.
I ended up getting a surge arrestor that mounts in the breaker panel and protects both legs of power that way. Also means that all I had to do was plug it into my power outlet. (It helps when you have a separate breaker panel for the workshop.)
Another cool thing about the unit is that in order to run it on 220V, all you have to do is connect it to that power source. The unit automatically senses what power it’s connected to and operates the same regardless of the voltage from the power source. To keep things simple, I ended up just making a pigtail that plugs into my 220V outlet and has a female 110V outlet end. I just plug the Voyager’s 110V plug into the pigtail, and plug that into my 220V power source.
If I want/need to connect it to a 110V circuit instead, I need only unplug it from the pigtail and I’m good to go.
