Rusty Miller said:Got my tape and it's on the saw. Seems like it will work fine. I'm going to put a fine white line on the pointer part of the depth ajuster so it will be easier to see.
Here's a couple of pics, a little dark where you need to see but you get the "picture".
Rusty
rrmccabe said:Rusty Miller said:Got my tape and it's on the saw. Seems like it will work fine. I'm going to put a fine white line on the pointer part of the depth ajuster so it will be easier to see.
Let me do some more checking and I'll let you know
Rusty
Rusty, that's the ATF55?
So it appears a decal needs to end at 1 5/8" on the ATF ?
Also you have checked the scale and with it zeroed out the marks line up at 1", 1 1/2" etc with where they should on the MM scale? So its correct scaling?
Is there anything that could be done with it to help ATF guys?
rrmccabe said:Here is a enhanced version of your picture. Curious where you have zero set it. It appears about 7 or 8 mm? Is your track 5mm like the TS55/75 saws?
Thanks Rusty.
rrmccabe said:Rusty can you print from a PDF?
Wondering if I can make you a template to test. I will send you an updated decal that's perfect if you want.
